Error trying re-run Data Assist Wizard
Thread begun 2/21/2014 11:47 am by Brendan | Last modified 2/21/2014 12:04 pm by Jason Byrnes | 910 views | 1 replies |
Brendan
I added 2 fields to my database, and need to be able to update them. Looked through the code on the update page, and wasn't sure I could add the 2 fields manually, so tried to re-run the wizard for just the update page.
Getting error
At line 2407 of file "C:\Users....\en_US\Configuration\Floaters\WA_Site_Tools_ProgressV2.js" :
getAvailableColumnByName(wa.dataassist_settings.available_colums,keyCol) has no properties
The error indicates that you are using a preset in the wizard that does not match the table.
if you edit the table settings, you will need to use the new from blank preset when running the wizard.
You should recreate all pages not just the update page.
