customer checkout session values
Thread begun 2/19/2014 8:07 am by CraigR | Last modified 2/24/2014 12:18 pm by CraigR | 4480 views | 9 replies |
CraigRBeta Tester
Just a quickie re ecart 5 vs ecart 6
When adding the server behaviour eCart Store Summary in Database, when it came to adding the order shipping details in v5, these were provided by session values created when posting the checkout page to the confirm page, (though I can’t remember if these were created by the checkout wizard or not) .
I noticed there don’t appear to be any similar session values created in ecart 6, but as the checkout process is a a bit different, I wanted to ensure I didn’t add something which already exists
eCart 6 uses a new persistence architecture. so to return a value from the checkout form, use:
<?php echo WA_getSavedFormValue('FormName','ElementName'); ?>
so for example if the form is named "CheckoutWizard_NewFromBlank_Default" and you want the email address:
<?php echo WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Email_Address'); ?>
CraigRBeta Tester
Great, thanks Jason, I'll give it a try
you're welcome.
CraigRBeta Tester
Works !
I added the line <?php require_once("path_to/webassist/forms/persist.php"); ?> at the top of my page
Then using the syntax you provided, updated the server behavior.
When adding a value to the column, clicking on the lightning bolt does not reveal any of the fields to bind, so they needed to be typed in manually, but it definitely works.
Yes, the code needs to be typed manually for now, i have logged a bug that there is not a way to add the code using the bindings panel, so this should be available soon.
CraigRBeta Tester
Since the release of Ecart 6.0.5 this seems to have stopped working, and the code is still not available in the binding panel
CraigRBeta Tester
Issue was due to 2 problems.
The payment gateway sandbox parameters were created in ecart 6.0.4 and the checkout wizard had not been re-run, so was still getting a transaction failure.
The confirm_cart.php page was checking for CheckoutWizard_submit button being posted before the WA_persistForm function was run.
I needed to check for this and the submit buttons for the other payment gateways I had added to ensure WA_persistForm was called
We resolved this in a connect meeting.
