no shipping_failure.php being Created
Thread begun 2/19/2014 5:54 am by bphilow1399308 | Last modified 2/24/2014 7:38 am by Jason Byrnes | 6014 views | 23 replies |
bphilow1399308
The cart is set up with Cookies
When I change the "any address field" on the checkout page the bottom of the page reloads to index with no Images. After searching I found this which should have shipping_failure.php filled in
//WA eCart USPS Shipping - USPS
$Shipping_SuccessURL = "";
$Shipping_FailureURL = "../../../../../../../";
$Shipping_Packaging = 0;
$Shipping_PackageArray = array();
$Shipping_PackageIndex = 0;
$Shipping_Counter = 0;
$Shipping_Parameters = array();
$Shipping_Parameters["ShiptoZip"] = "".WA_PP_ECO_GetValue($WA_PP_ECO_GetResult, "PostalCode") ."";
is this right?
and if so why isn't it being created with the wizard?
there is no shipping failure page created by the wizard, the code for the failure URL should be blank:
$Shipping_FailureURL = "";
I have logged a bug to have this corrected in the next update.
bphilow1399308
Still not working
when i update street. The bottom window "cart" redirects to "index" leaving the checkout page.
see pm
bphilow1399308
Thank You
Thank you that seams to have worked, But i don't think the shipping is calculating other then base rate and per item
I have it set up for USPS
I would set it up for Fedex but could you translate the field
From Fedex:
Production Password
From Ecart
Security Key
Password
I'm thinking
Security Key = Production Password
Password = My Password
in the add to cart button, make sure a weight is being set, the shipping lookup will only return a rate if a weight is passed
in the USPS shipping settings, you have First Class selected as the service, this is only valid if the weight is under 13 oz.
for details on obtaining the FFed Ex details, see this tutorial:
http://www.webassist.com/tutorials/Online-shipping-solutions-eCommerce-Series
bphilow1399308
Still No Shipping
I reinstalled Ecart from the Extension manager and deleted the cashed file in hopes it was an install problem.
The ../../../ must be manually removed still and shipping does not Update?
I have Updated the Site so you can see the weights are being passed to the cart. I followed the fedex tutorial and set up fedex.
Is this a bug with the new version? and if so when is the next update?
see PM
bphilow1399308
almost
thank you i feel much better, and i think we're almost there.
I updated the shipping lookup to use the correct form element names.
couple questions to reproduce some of these bugs so i can log them:
What Gateway are using?
What version of DW?
What is your OS?
