can I create payment subscription using ecart 6?
Thread begun 2/18/2014 1:15 am by Nutzo247 | Last modified 2/20/2014 9:03 am by Jason Byrnes | 3094 views | 5 replies |
Nutzo247
I'm planing to build a subscription system where the customer will be be charged on a monthly or annual basis can ecart6 hand that function alone or do I have to get additional services?
ecart does not have subscription payments built in, you would need to do some hand coding tho add that.
we could help you implement this in a premiere support appointment:
http://www.webassist.com/premier_request.php
Nutzo247
will additional coding still use ecart components or will it be a completely different build?
It will still use eCart as the basis. but custom coding will be needed to set up the subscription on paypal at checkout.
Nutzo247
will there be a need for custom coding subscription. if I decide to use SagePay?
Yes, custom coding will be needed for subscriptions regardless of the gateway you use.
