eCart 6 transaction failure with Authorize.net and PayPal express
Thread begun 2/15/2014 6:43 pm by larry268887 | Last modified 3/17/2014 11:19 am by larry268887 | 9824 views | 50 replies |
larry268887
I'm getting the same error as Lee. The logins are correct and I'm not in sandbox mode. These same logins work with Ecart5.
["WAAuthNet"]=> string(280) "3::2::13::The merchant login ID or password is invalid or the account is inactive.::::P::0::::::538.75::::auth_capture::::::::::::::::::::::::::::::::::::::::::::::::::::6B43302EFB245A713FA4CCB90B150D41:
Paypal Express just doesn't work. Sometimes when I run checkout wizard and then try to do a transaction the popup never appears and the checkout_failure page appears. Sometimes when I run checkout wizard and then try to do a transaction I get an object not found error.
Need help don't know to go from here.
larry268887
the files are on my local server and not sure how to put on server without messing up current working site.
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
larry268887
I'm available anytime today 573-734-6330
larry268887
pm
see PM
larry268887
I fixed that and now the checkout page comes up but when using paypal the screen dims and the page freezes. The popup never does come up. When using authorize.net and you hit the continue button the progress bar comes up and stops and the page is the same. The page doesn't contain the credit card info. On the local server it still gives the same error. And when you use paypal its trying to use aurthorize.net login credentials.
see PM.
larry268887
Do know when this will be released because I need this working.
