Test for Item in Cart to Prevent Adding Another
Thread begun 2/14/2014 12:39 pm by Mike Perry | Last modified 2/19/2014 8:50 am by Jason Byrnes | 2119 views | 5 replies |
Mike Perry
Is there a way to hide a product from a dynamic Repeating section unless a product that is required to be ordered has been placed in the cart? I have ItemIDs and playerIDs available in the cart; the test would look for a different playerID and the inclusion of a specific itemID.
Or is there a better way to test and implement?
Thanks,
Mike
you can test for an item by ID using inCart:
$cartObName->InCart("<ID Value>") == true
or you can do a conditional Total for a other columns
$cartObName->ConditionalTotal("Quantity", "playerID", "<id value>") > 0)
Mike Perry
I get the first one -- don't quite follow the second. What would <id value> represent??
the value you want to check for in the playerID column
conditionalTotal takes 3 arguments:
The column to total
The Conditional Column
The Value to check for
Say you had a color column and you wanted to now if any items where purchased with a color of red:
if($cartObName->ConditionalTotal("Quantity", "color", "red") > 0)) {
echo("there's a red item in the cart");
Mike Perry
Got it.
I've been trying to use this test in a repeating region to hiwith minimal success. Would it be possible to test for a needed item in the cart by attaching the test to the AddtoCart function in the cart definition, and if the required item is missing to throw a JS alert notifying the user they need to have a specified item prior to selecting this one?
I'm just looking for a clean way to let users know of the requirement.
Thanks, Jason. . .
Mike
"attaching the test to the AddtoCart function in the cart definition,"
Im not sure why that would be any cleaner than adding the notice beside the item, on the catalog page.
Im sure it would be possible to send a javascript alert, but would take custom coding to accomplish, this sort of customization is beyond the scope of the public forum, we could help implement this in a premiere incident:
webassist.com/premier_request.php
