VerfiedUser no longer working
Thread begun 2/14/2014 12:10 pm by sysop349733 | Last modified 2/17/2014 10:17 am by Jason Byrnes | 4175 views | 8 replies |
sysop349733
Hello,
I had successfully created a double opt in registration system, but then proceeded to start to apply user-level authentication and it appears as if I've broken the check for VerifiedUser somehow.
I've reverted to a previously successful login.php page, so I'm wondering if there is some support file I may have inadvertently changed.
Here are the symptoms:
- User can log in before completing the email verification process -- at least a successful login message is display on the login page which is shown on WA_Auth_RulePasses("Log in success")
- After successfully completing email verification and logging in, user cannot access pages that are set to require VerifiedUser through SecurityAssist Access Pages Manager. Database successfully update to emailVerified=1 but access is denied.
- As an additional test, I created a show region on the login page that would display if WA_Auth_RulePasses("VerifiedUser"). That area is not shown after a verified user logs in (login page reloads to login.php?loggedIn=1 on successful login.)
Like I said, I've examined the code on the login page and rolled back to a known working version, so I wonder if there is some helper file I should check, but I'm not sure where or what to look for.
This seems to be the relevant portion of the login page for your review. Any advice would be greatly appreciated.
if($_SERVER["REQUEST_METHOD"] == "POST"){
$WA_Auth_Parameter = array(
"connection" => [xxxxxxx],
"database" => [xxxxxx],
"tableName" => "[xxxxxx]",
"columns" => explode($WA_Auth_Separator,"UserEmail".$WA_Auth_Separator."UserPassword"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["Log_In_group_Email"]))?$_POST["Log_In_group_Email"]:"") ."".$WA_Auth_Separator."".(WA_CryptEncryption((isset($_POST["Log_In_group_Password"]))?$_POST["Log_In_group_Password"]:"")) .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"UserID".$WA_Auth_Separator."emailVerified"),
"sessionNames" => explode($WA_Auth_Separator,"SecurityAssist_UserID".$WA_Auth_Separator."emailVerified"),
"successRedirect" => "login.php?loggedIn=1",
"failRedirect" => "login.php?failedLogin=1",
"gotoPreviousURL" => TRUE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
if((((isset($_SESSION["SecurityAssist_UserID"]) && $_SESSION["SecurityAssist_UserID"] != "")?"LoggedIn":"") == "")&&(((isset($_COOKIE["AutoLoginUN"]))?$_COOKIE["AutoLoginUN"]:"") != "")&&(((isset($_COOKIE["AutoLoginPWD"]))?$_COOKIE["AutoLoginPWD"]:"") != "")){
"connection" => [xxxxxx],
"tableName" => [xxxxxx],
"columnValues" => explode($WA_Auth_Separator,"".((isset($_COOKIE["AutoLoginUN"]))?$_COOKIE["AutoLoginUN"]:"") ."".$WA_Auth_Separator."".(WA_CryptEncryption((isset($_COOKIE["AutoLoginPWD"]))?$_COOKIE["AutoLoginPWD"]:"")) .""),
"successRedirect" => "index.php",
"failRedirect" => "",
sysop349733
see private message
sysop349733
see private message
see PM
sysop349733
See PM
sysop349733
Read me first
Jason, before addressing my previous comments, I think the problem is resulting from my attempts to implement user-level access and likely from struggling with some directions I'm finding unclear. In the instructions for implementing user-level access is this sequence:
6. Choose the userLevel database column.
7. By default the name of the session variable
8. Select Finish.
I'm not sure what step 7 is instructing, exactly, and, if I click on the lightening bolt to select a value, nothing appears obvious to me as the proper value. (I had previously entered a numerical value, which obviously is not right and I think caused the original problems.)
I suspect if you can clarify these instructions for me, I can take it from here.
Also, see PM
sysop349733
Narrowed it down. See PM
see PM
