Continue Shopping button and dynamic results and detail pages
Thread begun 2/13/2014 3:57 am by m79618373377 | Last modified 2/13/2014 8:21 am by Jason Byrnes | 2789 views | 3 replies |
m79618373377
I am having problems with the 'Continue Shopping' Button and dynamic results and detail pages in ecart5.
As it stands if a user adds to the cart from the results page, they can click on the 'Continue Shopping' button in the cart and this redirects them back to the dynamic results page. This is fine. However, if they click on an 'Add to cart' button on a detail page, although it takes them to the cart, if they then click on a 'Continue Shopping' Button they are redirected back to the Detail page, when I require that they be redirected back to the dynamic results page.
After looking around the Community forums the only solution I could find was changing the code from 'Submit' to a button and using javascript with regarding to the 'Continue Shopping' button. For example:
<input type="button" name="WA_Store_Cart_Continue_100" id="WA_Store_Cart_Continue_100" value="Continue Shopping" alt="Continue Shopping" onClick="javascript: history.go(-1)"/>
There are two problems I perceive with this:
1. Although initially it seems workable, I would require two cart pages. One for the results page having a history of -1 and one for the detail page having a history of -2 with regard to the 'Continue Shopping' button.
2. Even if I decided to use the above method, this would still leave me in a predicament of what happens if someone clears the cart or removes an item and updates it. As soon as they click on any of these buttons, this would then refresh the page and users would have to click on the continue shopping button numerous times as the history would have changed.
Does anyone have a solution?
so regardless of where the user clicks the add to cart button, you want the continue shopping link to always point tot he results page?
just make the continue shopping button a link to the results page then:
<a href="results.php"><input type="button" name="WA_Store_Cart_Continue_100" id="WA_Store_Cart_Continue_100" value="Continue Shopping" alt="Continue Shopping" /></a>
m79618373377
Thanks Jason.
The problem with this is the results page is created by the user through a search using 'get': For example the URL may be :
http://www.domain.com/results.php?id=1 or http://www.domain.com/results.php?id=2
In other words the results page they need to be sent back to is dynamic and different in every case.
From my understanding using the code you mention I can only send them back to a generic results page. ie results.php without the search criteria created through a form (?id=1). Hence the reason for using a Javascript back history approach on the Continue Shopping button. The problem with this is that it will not work if a user empties or removes from the cart as they will have to click multiple times on the Continue Shopping button.
Is this a results page created by Data Assist? if so, the search is stored in a session so this will not be a problem
If this is a results page you created your self, you will need to store the ID in a session and use the session if the ID is not present.
