Selling products by dimension, like m, m2 and m3.
Client inserts width and height and the price is calculated based on the price per m2, or m3. Is it possible?
yes, it is possible to do this.
create a column in the cart object for height width and depth.
in the eCart add to c art button, set those columns to be updatable from a text box or select list.
you can add a calculation in the ecart objects calculations tab to calculate the price based on the entered values.
the exact calculation will depend on how you want it to work.
