Validation Toolkit Required Field Error
Thread begun 8/19/2009 7:58 pm by jmpuyo250448 | Last modified 8/20/2009 9:29 am by Jason Byrnes | 2855 views | 1 replies |
jmpuyo250448
Hello,
I had an error when trying to apply a Required/Not Blank/Selection Made validation to a text field or any other tag. After taking a look at the code that generated the error (Line 43 on WAFV_Required_C.js file) -> error: tagType undefined.
I managed to make the validation work by adding a line of code to this function on the file:
function applyBehavior() {
var theReference = "";
if (!isCommand) {
theReference = document.theForm.formElement.options[document.theForm.formElement.selectedIndex].text
else {
theReference = theElement;
var theForm = theReference.substring(0,theReference.indexOf("."));
var theField = theReference.substring(theReference.indexOf(".")+1);
theValue = "document.getElementById('" + theForm +"')."+theField;
setID(theForm);
var tagType = theElementType; //Added this line of code
if (tagType.toLowerCase()!="select" && tagType.toLowerCase()!="checkbox" && tagType.toLowerCase()!="radio") {
var theValue = theValue + ".value";
var errorMsg = encodeAlert(document.theForm.errorMSG.value);
var stopIt = getRadioVal(document.theForm.ErrorResult);
var trimWhite = !document.theForm.trimCHK.checked;
var theFocus = false;
if (isCommand) {
if (theElementType != "input.hidden") {
theFocus = theValue;
if (theElementType == "radio") {
theFocus += "[0]";
else if (document.theForm.formElement.options[document.theForm.formElement.selectedIndex].value == "true") {
theFocus = "document." + document.theForm.formElement.options[document.theForm.formElement.selectedIndex].text;
if (tagType == "radio")
theFocus += "[0]";
if (isCommand) {
return "WAValidateRQ("+"document." + theElement +",'"+errorMsg+"',"+theFocus+","+stopIt+","+trimWhite+",'"+tagType+"')";
else {
return "WAValidateRQ("+"document." + document.theForm.formElement.options[document.theForm.formElement.selectedIndex].text+",'"+errorMsg+"',"+theFocus+","+stopIt+","+trimWhite+",'"+tagType+"')";
The line of code added was:
in order to avoid the tagType not defined.
let me know if this is the correct solution to the problem.?
sounds right. The fix for this is attached to the following thread:
showthread.php?t=3172
