Problem with my blog
Thread begun 2/10/2014 10:24 am by russb335115 | Last modified 2/10/2014 1:21 pm by Jason Byrnes | 3082 views | 5 replies |
russb335115
My blog page isn't working correctly all of a sudden.
I use the premier service to set up a comments section on my blog which initially worked. Now it is only displaying once comment (the most current) multiple times.
Also on the page with the comments it is limiting the blog list that is on the right hand side of the page to 1 blog when it should list top 10.
russb335115
Se PM
i corrected the probelm by editing:
<h2>Blog Comments</h2>
<?php do { ?>
&nbsp;&nbsp;&nbsp;&nbsp;<?php echo $row_Comments['CommentTitle']; ?><h3 style="display:inline"> by: <?php echo $row_Comments['CommentBy']; ?></h3>
<p style="margin-bottom:20px"><?php echo $row_Comments['CommentText']; ?></p>
<?php } while ($row_BlogRS = mysql_fetch_assoc($BlogRS)); ?>
<?php do { ?>
<?php } while ($row_Comments = mysql_fetch_assoc($Comments)); ?>
basically, the repeat region was using the blogRS instead of the comments RS.
russb335115
Awesome, thanks Jason.
I will make sure to check that if this issue comes up again,
Best regards
you're welcome.
