Using ecart for real estate
Thread begun 2/10/2014 9:25 am by m79618373377 | Last modified 2/10/2014 12:04 pm by Jason Byrnes | 2738 views | 5 replies |
m79618373377
I have nearly finished completing a real estate website using Web Assist. However, I require a cart that a website user can collect various properties and send these chosen properties to an email address. In effect the user should only be able to select each property once and send the details in a single email to an email address I choose. They should be able to delete a property from their list before sending.
Therefore I do not require any payment system etc. Is ecart the best tool to use for this or is it total overkill and one of the other webassist extensions more appropriate?
In the eCart checkout wizard, you can select to use no gateway.
as for deleting the property listing, you would need to hand code that portion.
m79618373377
Hi Jason,
Thanks for this. Surely there is someway in the cart to delete an option selected. Maybe I didn't explain myself clearly.
1. What I require is the viewer be able to delete a property from the cart before it is sent to the email address incase they have changed their mind. Pretty much as most shopping carts out there.
2. The option that the user can only choose the property once. In effect, if they choose it again, the user is not prompted but it is physically not possible to add it twice, or alternatively tells the user that they have already added it, so they can't add it again.
I thought you where asking about removing from the database.
1) yes, there is an option to remove items from the cart.
2) in the add to c art button behavior, you can set that if the item exists in the cart, it is ignored.
m79618373377
Sorry, my fault for not explaining more clearly.
Just one other question, is that the same for ecart 5 and 6? Although we intend on upgrading to 6 in the near future, unless there is anything beneficial in doing so for this particular situation, we will wait until we need it for a cart that requires a gateway etc.
yes, it is the same in both eCart 5 and in eCart 6.
