How do I get back spry validation?
Thread begun 2/10/2014 3:26 am by info4753 | Last modified 2/10/2014 9:11 am by Jason Byrnes | 9710 views | 7 replies |
info4753
When I create a new dataassist form spry validation has been replaced by jquery validation. How do I get back to the spry validation? All the designed validation stuff is gone and this looks bad compared to already created pages.
Spry Validation has been depreciated by Adobe.
It is not longer available as an option In Dreamweaver CC, this is why it has been removed from Data Bridge.
if you have a previous version of Dreamweaver, you can add spry manually by selecting an element and going to insert -> form -> Spry text field.
but in Dreamweaver CC, it is no longer an option.
bear in mind, that spry and jquery validations will not work side by side, so you will need to remove the jquery validation before adding the spry validation.
info4753
I see, thanks. Is there a way to create a jquery validation that is similar to the spry validation? If I add a new form I get tooltip instead of a red boxed field and I have therefore reapply all forms which takes one or two days to be done.
in the spry options script, you could add an errorClass, for example:
var form1_Opts = {
focusout: true,
focusin: false,
change: false,
keyup: false,
popupClass: "Bloom",
pointedAt: "left",
fieldOffset: 10,
fieldMargin: 2,
position: "left",
direction: "left",
border: 1,
offset: 25,
closeText: "?",
percentWidth: 100,
orientation: "bottom",
errorClass: "fieldError",
then add CSS to set the errorClass appearance:
<style type="text/css">
.fieldError { background-color:red; }
</style>
info4753
You mean like this I can replace the tooltip JQuery error note in the DW-CC version of DataBridge?
no., it wont replace the tooltip, but will allow you to customize the llok of the field on error.
it's not posible to remove the tooltip.
info4753
ok, thanks.
you're welcome.
