Deprecated: mysql_pconnect()
Thread begun 2/07/2014 8:10 am by Brendan | Last modified 2/11/2014 9:10 am by Jason Byrnes | 8310 views | 7 replies |
Brendan
Using Xampp v3.2.1 to test, Windows 7, DW CC, most recent version of Data Bridge.
I just ran the SA wizard to create registration, login, logout, update, and forgot password pages, when preview in DW I get this full error message at the top of every page.
Deprecated: mysql_pconnect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in H:\Sites\ISRC_14\Connections\Local.php on line 11
here is what is contained in local.php
# FileName="WADYN_CONN.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_Local = "isrc.local";
$database_Local = "isrc";
$username_Local = "root";
$password_Local = "rugbyc12";
@session_start();
/*Line 11 - */ $Local = mysql_pconnect($hostname_Local, $username_Local, $password_Local) or trigger_error(mysql_error(),E_USER_ERROR);
make sure the mysql library is enabled in the php.ini file.
you may also want to change the error reporting level to not include deprecated warnings.
we will be upgrading Data Bridge to use the mysqli library instead in the near future.
Brendan
It appears as though the mysql library is active
**from php.ini **
;extension=php_mssql.dll
;extension=php_mbstring.dll
;extension=php_exif.dll ; Must be after mbstring as it depends on it
extension=php_mysql.dll
extension=php_mysqli.dll
;extension=php_oci8.dll ; Use with Oracle 10gR2 Instant Client
;extension=php_oci8_11g.dll ; Use with Oracle 11gR2 Instant Client
I am not sure how/where to disable error reporting.
I have tried to test my SA pages, but they are not working.
register.php - enter all info, and i get an error message "Invalid information, please check your entries and try again."
in the php.ini fiule, there is a setting for error reporting:
http://us3.php.net/manual/en/errorfunc.configuration.php#ini.error-reporting
for the registration page,
I'll need to troubleshoot directly, see the private message section. if you are testing locally, you will need to upload to a live server in order for to troubleshoot.
Brendan
I only have this issue on my local server. It seems like the security answers aren't validating locally, but are working on my live server.
There is probably an issue with saving session information on the local server then.
try running the attached session test file. if the test fails, it is probably a bad session.save_path in the php.ini file.
Brendan
You are correct, there is an issue on my end, the session shows NULL after clicking the second link. Any suggestions on how to correct my session save path?
edit the php.ini file and set the session.save path to valid directory:
http://us3.php.net/manual/en/session.configuration.php#ini.session.save-path
