IE9 not playing well with php
Thread begun 2/06/2014 12:29 pm by Ericspecullaas | Last modified 2/06/2014 12:35 pm by Jason Byrnes | 856 views | 1 replies |
Ericspecullaas
Greetings!!
I have built a search engine using data bridge it works perfectly in Firefox Chrome and in Safari but thanks to good old IE it stops working in version 9. when the query is sent to page it refuses to filter the results via a search word like hat. It will show all results here is my code for the search bar and for the reciving php code
<?php require_once('Connections/acme.php.inc'); ?>
if (PHP_VERSION < 6) {
$theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue; // removes magic quotes
$theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue); //this is the filter for all bad code injection
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_acme, $acme);
$query_Recordset1 = "SELECT * FROM project";
$Recordset1 = mysql_query($query_Recordset1, $acme) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$totalRows_Recordset1 = mysql_num_rows($Recordset1);
<?php require_once("webassist/form_validations/wavt_validatedform_php.php"); ?>
and for the reciving page
<?php require_once("webassist/database_management/wada_search.php"); ?>
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: WADAproject;
//Searchpage: project_search-test.php;
//Form: WADASearchForm;
$WADbSearch1_DefaultWhere = "";
if (isset($_GET["Search"]) || isset($_GET["Search_x"])) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
//comparison list additions
$WADbSearch1->addComparisonFromEdit("searchWords","searchWords","AND","Includes",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_project_resultstest"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_project_resultstest"]) && $_SESSION["WADbSearch1_project_resultstest"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_project_resultstest"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$currentPage = $_SERVER["PHP_SELF"];
$maxRows_WADAproject = 10;
$pageNum_WADAproject = 0;
if (isset($_GET['pageNum_WADAproject'])) {
$pageNum_WADAproject = $_GET['pageNum_WADAproject'];
$startRow_WADAproject = $pageNum_WADAproject * $maxRows_WADAproject;
$query_WADAproject = "SELECT * FROM project";
setQueryBuilderSource($query_WADAproject,$WADbSearch1,false);
$query_limit_WADAproject = sprintf("%s LIMIT %d, %d", $query_WADAproject, $startRow_WADAproject, $maxRows_WADAproject);
$WADAproject = mysql_query($query_limit_WADAproject, $acme) or die(mysql_error());
$row_WADAproject = mysql_fetch_assoc($WADAproject);
if (isset($_GET['totalRows_WADAproject'])) {
$totalRows_WADAproject = $_GET['totalRows_WADAproject'];
} else {
$all_WADAproject = mysql_query($query_WADAproject, $acme);
$totalRows_WADAproject = mysql_num_rows($all_WADAproject);
$totalPages_WADAproject = ceil($totalRows_WADAproject/$maxRows_WADAproject)-1;
$queryString_WADAproject = "";
if (!empty($_SERVER['QUERY_STRING'])) {
$params = explode("&", $_SERVER['QUERY_STRING']);
$newParams = array();
foreach ($params as $param) {
if (stristr($param, "pageNum_WADAproject") == false &&
stristr($param, "totalRows_WADAproject") == false) {
array_push($newParams, $param);
if (count($newParams) != 0) {
$queryString_WADAproject = "&" . htmlentities(implode("&", $newParams));
$queryString_WADAproject = sprintf("&totalRows_WADAproject=%d%s", $totalRows_WADAproject, $queryString_WADAproject);
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = false;
$RepeatSelectionCounter_1_Iterations = "3";
as a side note when I was building this I set the search bar to equal not to include.
thanks in advanced
most likely you are using the enter key to submit instead of actually clicking the submit button.
as a work around try adding a hidden element name Search to the search form.
