Static option on dynamic cart
Thread began 2/06/2014 2:07 am by jon392819 | Last modified 2/06/2014 2:13 pm by Jason Byrnes | 2343 views | 11 replies |
jon392819
Hi Guys, I have a dynamic cart working fine. One of teh products needs a size option of small, medium and large.
Is it possible to add a static size dropdown to a dynamic cart? It would be easy to show / hide the size drop down beside the add to cart button for the product in question, but is it possible to grab the selected size?
Thanks a million
yes, it would be the same as adding a regular static option.
just add an if statement around the select list so it only shows for the one product.
and another if statement to add a hidden element of the same name for other products
jon392819
Thanks Jason, Added size as a column to the ecart object. Creating a new add to cart button I am unsure what to do with the size field?
Jon
set it to be updateable as as select list.
see the Static options tutorial:
http://www.webassist.com/tutorials/Add-static-product-options-eCommerce-Series
jon392819
Thanks, got it working, I had to delete the display manager to show the new size, this is fine but now when I try to redo the checkout wizard I get a javascript error.. Cleared the site cache files but no joy. I attach the error message. Thanks for your help. Jon
in the WA_eCart folder, delete the WA_DMCFG.xml file.
jon392819
Thanks Jason, Im not having a good day here for some reason. I have the display manager working but I get the following now when trying to run the checkout wizard. (sdee attached)
I have dozens of ecarts working fine. This one I wish I had never started. :)
Thanks again jason.
try restarting the system, then Delete the Dreamweaver Cache file from the users configuration folder:
and reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
jon392819
No luck Jason. Same error message. Shut down, cleared the cache files and reset workspace.
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
