Adding Photo Upload to users_update.php
Thread begun 2/05/2014 11:34 am by david323147 | Last modified 2/07/2014 12:16 pm by Jason Byrnes | 6472 views | 23 replies |
david323147
My users_date page is working fine but I need to add the ability to upload a photo and then have it appear on the users_detail.php page. Here are the steps I took:
1. Created the new div on the update page and added a file field from the insert>forms menu.
2. WebAssist>File Manipulation>Upload.
3. I configured the settings as shown in the two images attached. The upload folder was created earlier.
4. Uploaded the users_update.php file and webassist folder to my remote server.
5. When I try uploading a photo, it doesn't appear in the remote folder. I get no error messages.
Once this is working, can I have the image appear on the users_detail.php page by dragging the binding for the photo from the bindings panel?
I am attaching my users_update.php file.
Thanks.
for file upload to work, the form method needs to be set to multi part form data.
select the form tag, then in the property inspector, change the encoding type to multipart/form-data
david323147
Great, thank you! That is working now.
But now I'm trying to get the image to appear on the users_detail.php page. I'm following the tutorial "Add file fields to Data Bridge insert / update pages
". When I do Insert>Image and click on the Data Sources button, I get a dialog box saying, "This feature is used in documents that execute on the testing server. Would you like to change the type of the current document?" There are No and Yes options. No just brings me back to the select an image dialog and I don't think I want to change the document type. I do have a testing server setup but I've been building the site on the remote server and really not using the testing server. I want to do this on the remote server.
I'm attaching the users_detail.php page for your perusal.
Thanks Jason, you've been a TREMENDOUS help so far!
the dreamweaver site settings must be set to connect to a server for testing. you can set this up to use the remote server settings for the testing server in the site, but the testing server is needed for dynamic development.
when you go to the bindings tab, can you access the dynamic bindings?
if not, you need a testing server defined.
david323147
I changed my settings in DW so that the remote server is both the remote and testing server. When I go to the Bindings panel and try to access the Recordset (WADAUsers), I get the following error:
HTTP Error Code 404 File Not Found. Here are some possible reasons for the problem:
1) There is no testing server running on the server machine.
2) The testing server specified for this site does not map to the http://letsparksfly.com/www/test/_mmServerScripts/MMHTTPDB.php URL. Verify that the URL Prefix maps to the root of the site.
If I configure DW so that my local server is the testing server and in my database definition I select the remote server, everything else had been working. This is how I have been doing things.
And yes, I can access the dynamic bindings in the bindings panel. I can see all the records under RecordsetWADAusers except the one for this image record.
i would think the url for the testing server should be :
http://letsparksfly.com/test/
instead of http://letsparksfly.com/www/test/
david323147
Well, I changed it to http://letsparksfly.com/test/, I can still access everything from the bindings and server behaviors panels, but when I click the Data Source button on the insert image dialog box, I still get "This feature is used in documents that execute on the testing server.Would you like to change the type of the current document?" Then the No or Yes buttons.
try adding the image element using a static source, then in code view, replace the image name with the recordset binding.
david323147
Okay, I manually added the binding and was able to drag the binding to the spot I want the image to appear and it works. BUT, I had to manually enter the image path for the record for the chosen record (doing so though phpMyadmin). The users_update.php page uploads the file to the directory, but it doesn't update the the appropriate column for that user in the table.
I've attached the users_update.php file.
you have to edit the update record serve behavior and bind the image column to he server file name from the upload.
see this tutorial for details:
http://www.webassist.com/tutorials/Add-file-fields-to-Data-Bridge-insert-update-pages
