continue shopping redirect question
Thread begun 2/03/2014 6:18 pm by JBWebWorks | Last modified 2/04/2014 11:27 am by Jason Byrnes | 4591 views | 9 replies |
JBWebWorks
products page has bicycle tours choices with a select list of product choices from each tour. Customer picks product and adds to cart. When they click 'Continue Shopping' it takes them to the top of the products page and I want it to go to the select list that they just added a product from. Can this be done with some type of named anchor?
Link to products page http://www.comfycampers.info/products.php
yes, you can add the anchor just above the cart form.
use the product ID as the anchor name.
edit the cart form action to include the anchor.
JBWebWorks
Jason,
Not sure what edit should be done to the form action?
This is form action now
<form action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>"
And what, if anything, should be done to the 'Continue Shopping' button?
this is the current redirect from the cart continue shopping
// WA eCart Continue Shopping
if (isset($_POST["comfycampers_Continue_100"]) || isset($_POST["comfycampers_Continue_100_x"])) {
$Redirect_redirStr="";
if (true && isset($_SESSION['WAEC_ContinueRedirect'])) {
$Redirect_redirStr=siteToPageRel($_SESSION['WAEC_ContinueRedirect']);
if ($Redirect_redirStr != "") {
$comfycampers->redirStr = $Redirect_redirStr;
$comfycampers->cartAction = "Continue";
add the anchor at the end of the action:
"<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>#<id val>"
where <id val> is the product ID.
nothing needs to be done to the continue shopping code.
JBWebWorks
Jason,
It's not working?
Here is the anchor and the form action
<a name="<?php echo $row_rs_products['ProductID']; ?>"></a><form action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>#<?php echo $row_rs_products['ProductID']; ?>"
send a coy of the page please.
JBWebWorks
included products page and cart page
on the products page, try changing line 144-149:
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "")  {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING']."#".$ATC_itemID."";
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."#".$ATC_itemID."";
JBWebWorks
That did it; works just like I need.
Thanks Jason!
you're welcome.
