layout problem
Hey Jason
If you have 5 mins, could you please look at http://clients.motley.co.uk/ITEAC/contact.php
Basically, it *should* look like the attached screenshot, but as soon as the large element in the sidebar is added (the one with the grey background in the right hand column) all the layout gets completely thrown off as you can see here http://clients.motley.co.uk/ITEAC/contact.php
The problem seems to be the length and/or content of the big grey element as when that is removed, the right column elements stack nicely on top of each other and the rest of the page renders perfectly.... but I cant figure out what is actually causing it
cheers
Jamie
