Problems installing Super Suite on Dreamweaver CC.
Thread began 2/02/2014 8:35 pm by Alberto | Last modified 2/04/2014 6:55 pm by Jason Byrnes | 1605 views | 3 replies |
Alberto
I've purchased super suite on jun/2013. Since last month I started to use dreamweaver cc. I've downloaded the installation files for Dreamweaver CC but the extensions are not working. The installation process runs ok, but when I try to use the extensions, nothing works. What should I do?
Make sure that you have the server behaviors extension installed:
http://www.webassist.com/tutorials/Server-behaviors-for-Dreamweaver-Creative-Cloud
also, make sure you have the latest versions of the web assist extensions installed:
eCart 6.0.3
Design Extender 1.1.7
Data Bridge 1.1.8
if you have previous versions installed, you should uninstall them before installing the newer ones.
after the install competes, open DW and open a PHP to start the WebAssist installer.
after the WA Installer completes, don't forget to restart DW.
Alberto
OK. Did as you said. Everything worked fine. Thanks for your help.
glad to hear it is working.
