Google maps with fancybox3 - is it possible?
Thread begun 2/02/2014 3:36 pm by mrs | Last modified 2/06/2014 8:54 am by Jason Byrnes | 3621 views | 3 replies |
mrs
I have a list of about 100 distributors for car parts, and each distributor has an address which I was hoping I could trigger a google map within the jQuery fancybox3, but when I click and the fancybox opens, I get a message of:
'The requested content cannot be loaded. Please try again later.'
Is there something stopping google maps from loading in a fancybox / shadowbox effect?
I have used the same database table in a different recordset to display all distributors on a single map elsewhere which is working fine, so I know my info for the addresses works OK.
I've attached the page to see if you can see anything that might prevent it.
Thanks.
I dont see why it shouldn't work, I'd need a URL where i can see the problem though, to investigate.
mrs
It's OK, I've managed to sort it out now. Rather than have the code inline in the page, I have added the map to another page which I am then pulling into fancybox via an iframe. It's actually worked out better as the page is now smaller in file size!
glad to hear it is working.
