Text alignment question.
Thread begun 1/31/2014 12:22 pm by operations439446 | Last modified 2/06/2014 12:16 pm by operations439446 | 4677 views | 8 replies |
operations439446
On the form when there is not a required red star the text moves forward to fill the space. I am trying to keep the end of all the text lines, lined up on the right with all the text required or not. So if the line is not required the text does not move forward to fill the red star area. See below image and here is a link to the test site http://americanmadegoods.net/betatwo/loan-application.php
One other question on this form. I would like to move the fields to the right so all the text is on on line and the form more fully fills the gray area. Right now its crammed into the left area.
Thanks,
Bob
the label for required fields adds a span tag with a asterisk in it:
<label for="First_Name" class="sublabel" > First Name:<span class="requiredIndicator">&nbsp;*</span></label>
for the not required fields, you'll need to add the same span, but empty:
<label for=" FICO Credit Score:" class="sublabel" > FICO Credit Score: Name:<span class="requiredIndicator">&nbsp;&nbsp;</span></label>
when you run the form builder wizard, in the design settings, you can specify the width for the labels. It is wrapping to a new line because the width is set to narrow to fit your full label on one line.
operations439446
Hi Jason,
Excellent all is working as you direct. One more question on spacing. Here is a form with a long label (3 lines) and it's required. How can I pull the top two lines back to line up with the rest. Here is a link http://americanmadegoods.net/betatwo/brokers.php
It the line that say:
Purchase Price or
Current Market
As always,
Thanks,
Bob
in the webassist/forms/fd_basic_brokersinquiry.css file change the width for the form.Basic_BrokersInquiry label.sublabel selctor to something like 180px
operations439446
Hi Jason,
Line to long, still on 2 line.
keep increasing the width....
operations439446
Hi Jason,
The lines are to long to make the form width that long. There must be a way to get a space in front of a line of text?
Look at the line "Purchase Price or" and "Current Market" Value: *
Not with the way the line wraps.
operations439446
Cool, thanks for the info. Good to know limitations.
