pp_confirm.php generated contains syntax errors
Thread begun 1/29/2014 4:02 am by acornist | Last modified 1/29/2014 10:05 am by acornist | 987 views | 2 replies |
acornistBeta Tester
after running the checkout wizard, the pp_confirm.php file that gets generated contains syntax errors at lines 154, 215 and 246:
$WA_fieldValuesStr = @@FieldValueStrParam@@;
I assume it should be:
$WA_fieldValuesStr = "@@FieldValueStrParam@@";
Anything I might be doing wrong?
eCart 6.0.2, macosx, dreamweaver CC
I ran across this issue with the beta version of eCart, but have not experienced in the release version.
Did you participoate in the eCart beta?
try and Deleting the Dreamweaver Cache file from the users configuration folder:
or rename the configuration folder to start from a clean installation.
http://helpx.adobe.com/dreamweaver/kb/troubleshoot-javascript-errors-dreamweaver-cs4.html#main_user_config
acornistBeta Tester
see pm
