Cannot complete frm builder wizard
Thread began 1/29/2014 3:56 am by superpac250441 | Last modified 10/16/2015 8:58 am by Ray Borduin | 1668 views | 10 replies |
superpac250441
When I click finish, it opens up UPDATE default values of the form elements panel If I configure all values and all input boxes and press OK and then FINISH, it reopens the update default values for each form element. So I cannot finish form builder even if I leave all the default values empty. Anny ideas why this is happening?
I just talked to Ray about this, it seams to be a bug when adding a form that contains security elements (ie. Captcha and Honeyots) we will have an update released tomorrow to correct the problem, i will let you know when it is available.
superpac250441
Thanks Jason
Justin did a hot fix build of the Data Bridge installer files.
try uninstalling Data Bridge and Reinstalling to run the install with the latest build that should correct this problem. The official update will be available soon.
superpac250441
Thanks a million Jason
you're welcome, the official upgrade to Data Bridge 1.1.8 was also released on Friday.
superpac250441
Thanks Jason, I picked that up
superpac250441
Unable to activate extensions
private message
superpac250441
This post has been deleted.
You can reset your activations at any time in order to install on a new computer. Just click the link on this page: http://www.webassist.com/account/downloads.php
I've reset them for you already so it should work now.
