Connection(s) to Existing Database
Thread begun 8/19/2009 12:45 pm by robert222776 | Last modified 8/24/2009 12:09 pm by Eric Mittman | 3340 views | 3 replies |
robert222776
I have an existing client php site with a database I built and connected to with DW db connections and server behaviors, etc., that utilize a dynamic master/detail page relationship. The database is simple, with a table for members and one for users. Consequently, I already have a Connection folder and file. In addition, as part of the above, I already have a simple CMS to handle member/user edits, additions, and deletions of database records. Again, all built DW server behaviors prior to my having any WA products. Also, obviously we are dealing with a live server and not a testing server situation.
1. Now I want to add PowerCMS to the mix. I have already added the PowerCMS tables to the existing database. My first thought is that I want to leave the existing CMS as is, and use PowerCMS to "manage" the rest of the static site pages. Is that the recommended approach, as opposed to abandoning the existing CMS in favor of using PowerCMS to manage the entire site?
2. Assuming that I leave the current CMS in place, now the question is what to do with the Connections folder at the "root" of the CMS100 folder. I would prefer to leave all the PowerCMS folders and files inside of the CMS100 folder at the site root to keep things tidy, instead of placing them separately at the site root (where the other Connection folder resides). With the CMS100 folder in place at the site root, it seems like I would need a second database connection for the benefit of the PowerCMS files. Do I really need more than one connection to the same database with this scenario?
3. I suppose another option is to create a second database for PowerCMS and make the connection to that database, but that seems somewhat redundant and unnecessary. True?
4. How do you recommend I proceed in this situation?
Thanks,
Robert
There is going to be a problem with trying to have a single connection file for all of the pages in your setup. The problem is that the pages that were created with the existing connection will reference that connections name in the code for the recordsets and other db manipulation. The connection for PowerCMS is called localhost, so if your existing connection does not have the same name it will not work to have a single connection for the pages without updating your existing pages to work with the new connection file.
So you can either leave your connection file in place and have the PowerCMS connection file in its folder or you can update the require once line for your connection file and the connection name on your existing pages to use the new PowerCMS connection.
To update your existing pages you would update the require once to go into the CMS100 folder and then into Connections/localhost.php. You would also need to update the code on the page, you will need to look for the connection variable and update it to be the new $localhost value.
robert222776
Thanks Eric. I made a second db connection that works fine.
From other posts on this forum and from the WA documents I was able to create a test page that I can see, and edit/update its content without the benefit of my pre-existing stylesheet for this site.
Now I would like to "attach" my pre-existing style sheet via IRite. I have tried to follow the steps (from Jason) outlined in another post dealing with "PowerCMS and IRite" without success. When I follow his suggestions and use the IRite Wizard on the content_update.php file I am getting the following error. See the before and after code:
Before:
// WebAssist iRite: Rich Text Editor for Dreamweaver
$WARichTextEditor_1 = CreateRichTextEditor ("ContentValue", "../WA_iRite/", "713px", "400px", "Custom", "../custom/contents_update_ContentValue1.js", "".($totalRows_HistoryUpdate > 0)?$row_HistoryUpdate['HistoryValue']:($row_WADAContents['ContentValue']) ."");
After:
$WARichTextEditor_2 = CreateRichTextEditor ("myStyles", "../../WA_iRite/", "100%", "200px", "Default", "../custom/contents_update_myStyles1.js", "");
This line is also inserted at the top of the page with the others:
<?php require_once("../../WA_iRite/WARichEditorPHP.php"); ?>
When I upload the file I get the following error:
Warning: main(mydomain/WA_iRite/fckeditor.php) [function.main]: failed to open stream: No such file or directory in /mydomain/WA_iRite/WARichEditorPHP.php on line 1
Fatal error: main() [function.require]: Failed opening required '/mydomain/WA_iRite/fckeditor.php' (include_path='.:/opt/php/lib/php/') in /mydomain/WA_iRite/WARichEditorPHP.php on line 1
Also, I do not see any file called "contents_update_myStyles1.js" which was named in the above "after" code.
Any suggestions?
Thanks,
Robert
When I look at the update page for the contents I can see that the iRite editor include code looks like this:
<?php require_once("../WA_iRite/WARichEditorPHP.php"); ?>
The error message you are getting indicates that there is a problem with the include path you have on this page. Please adjust this path accordingly so that the correct include file is referenced when the page loads. This should resolve the error.
The js file referenced is contained inside of the iRite folder in your site. You may also want to upload the iRite folder for the site again if it is not found on the server.
