javascript error
Thread begun 8/19/2009 11:57 am by rayne202093 | Last modified 8/19/2009 5:00 pm by Eric Mittman | 1963 views | 1 replies |
rayne202093
javascript error
I have installed the eCart 4.5.0 extension and the powerstore 2.0. When I try to access the eCart Object I receive a javascript error:
While executing timer in WA eCart Object.htm, the following JavaScript error(s) occured:
At line 257 of file "C:\Program Files (x86)\Adobe\Adobe DreamweaverCS4\Configuration\Commands\WA eCart Object.js"; document.generalWP.document.objPersistance.options[OBJECTDEF.Persistance] has no properties and the ecart dialog box is empty.
I have deleted the Dreamweaver cache file and restarted but the javascript error persists. How do I make this error go away.
I am using Vista 64 and DW4.
Thanks.
--rayne
If you have cleared out the cache and are still getting this error then you may have a corrupt configuration folder. Here is a link to a thread that discusses clearing this out by renaming or deleting it. This will also force you to re-install your extensions after the fact though.
showpost.php?p=12293&postcount=2
If the issue is due to some corruption this should help.
