CSS form builder UI window loop problem
Thread begun 1/26/2014 11:17 am by ezyweb9926 | Last modified 1/31/2014 8:52 am by Jason Byrnes | 3953 views | 13 replies |
ezyweb9926
Hello,
I have just upgraded to ecart 6 and I already have databridge 1.14 on Dreamweaver cs6 on Mac osx 10.9.1.
The issue is when I try to create or edit a css form using the css form builder. The clicking ok on the main form builder window opens the edit field values window, so I click on ok and go back to the main window and click ok, then edit field values window opens etc etc. This cycle just continues and the builder won't apply my changes to the form because the main form builder window won't close.
Can you please offer advise on how to fix this.
Thank you,
Mark.
russ278131
I have the exact same problem. I really need to use this.
My versions are: Data Bridge: 1.1.7, Design Extender 1.1.7, Free Tools: 1.0.8, eCart: 6.0.2 running with DWCC on Windows 7
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
russ278131
Sending my number privately, thanks.
I just talked to Ray about this, it seams to be a bug when adding a form that contains security elements (ie. Captcha and Honeyots) we will have an update released tomorrow to correct the problem, i will let you know when it is available.
russ278131
Thank you for your quick response.
you're welcome, i'll let you know when the update is available.
ezyweb9926
Hi Jason, yes and thank you from me too, I look forward to downloading the update. Mark.
ezyweb9926
Hi Jason, any word on the update?
it should be available tonight,
