Is there a something that I am not doing to get the eCart plug-in to work correctly.
I am following the tutorial: http://www.webassist.com/tutorials/Getting-started-with-eCart-6. I've downloaded and installed the plug-in. I've also installed the sample database. I created a new PHP page for the purpose of following along as well. I made the connection to the database using Dreamweaver and even made sure that the tables are present under the database menu. When I insert the eCart Object (and leaving the options as they are) and press the FINISH Button, only comments are added to the PHP page. Then, I use the Display Manager button under the Insert menu and still nothing happens. Anyone else having issues with eCart6 in this manner?
