show $ if / insert inserts 0 vs null
Thread begun 1/22/2014 11:18 am by jo271221 | Last modified 1/23/2014 7:29 am by Jason Byrnes | 2180 views | 3 replies |
jo271221
For some reason the value 0 is getting inserted when a new record is added.
The price field is type double in my database (not sure why - what does double mean), length is 25, decimals 0, and allow null and I have the default as null so I don't know why 0 is getting inserted.
I resolved the display problem by changing my showif from
if ($row_WADAtbl_posts['price'] != '0') {
</strong>$&nbsp;<?php echo $row_WADAtbl_posts['price']; ?>
to <?php
if ($row_WADAtbl_posts['price'] != '0' && $row_WADAtbl_posts['price'] !='' ) {
but I am still curious as to why 0 is getting inserted.
the data type double means a double byte integer
In the insert record behavior, that column would be set as numeric.
the insert behavior will use
floatval()
to ensure that text is not injected to a numeric column to prevent SQL injection.
when the string is empty, the flaotval() of "" is 0
jo271221
Thank You. So if I understand correctly I should just leave everything as is. - ?
yes, leave it as is.
