Admin in User Registration Solution Pack
Thread begun 8/19/2009 7:55 am by michaelf0199272 | Last modified 9/30/2009 7:01 pm by michaelf0199272 | 14013 views | 19 replies |
michaelf0199272
Q: Is there a logout page for the Admin portion of the User Registration Solution Pack?
This is because -- I triead to associate users_LogOut.php with it it did not seem to have any effect -- session still tayed active.
Q2: Does anyone have an input as to how best to effect a good logout on the Admin portion of the User Registration Solution Pack ?
in the Admin Directory, you can create a logout.php file.
and add the following code:
<?php require_once( "../WA_Globals/WA_Globals.php" ); ?>
require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
if(isset($_SESSION['AdminLogin'])) {
    unset(
$_SESSION['AdminLogin']);
if (!WA_Auth_RulePasses("Administrator")){
WA_Auth_RestrictAccess("users_LogIn.php");
michaelf0199272
Many thanks. I will try it out sometimes tonight.
Once again, thank you.
Michael
eaw500250991
This post has been deleted.
michaelf0199272
    unset(
php <-- This line 7
When I tried the codes provided on a logout page -- below is the error message that I got.
"Parse error: syntax error, unexpected '<' in /misc/39/000/158/672/0/user/web/africanregister.info/Admin/admin_LogOut.php on line 7"
.<?php <-- This line 7
Sorry, the code had a slight syntax error, use this code:
    unset(
michaelf0199272
I will try it out later this evening -- when I looked at the codes it seem the difference is " ;" instead of just ";".
Thanks,
Michael
No, the diferance is the closing php tag at line 6:
original: line 6 and 7:
New: line 5, 6 and 7:
michaelf0199272
I am still getting errors -- please see the error below.
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /misc/39/000/158/672/0/user/web/africanregister.info/Admin/admin_LogOut.php:2) in /misc/39/000/158/672/0/user/web/africanregister.info/WA_SecurityAssist/Helper_PHP.php on line 5
Warning: Cannot modify header information - headers already sent by (output started at /misc/39/000/158/672/0/user/web/africanregister.info/Admin/admin_LogOut.php:2) in /misc/39/000/158/672/0/user/web/africanregister.info/WA_SecurityAssist/Helper_PHP.php on line 67
make sure there are no blank spaces after the closing php tags, for example:
"<?php require_once( "../WA_Globals/WA_Globals.php" ); ?> "
or:
"<?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?> "
also make sure there are no blanlines between php code blocks such as:
<?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>"
If you are still having problems send a copy of the page so I can examine the code.
