I had this error when Dreamweaver first starts up. "The following Javascript error(s) occurred: Unable to open script file"C:\Programfiles(x86)\adobe\adobedreamweaverCS6\configuration\shared\webassist\cssmenuwriter\shared.js(error 3)"" ..I received
Thread begun 1/22/2014 8:55 am by bill181745 | Last modified 1/22/2014 9:04 am by Jason Byrnes | 1461 views | 1 replies |
bill181745
I had this error when Dreamweaver first starts up. "The following Javascript error(s) occurred: Unable to open script file"C:\Programfiles(x86)\adobe\adobedreamweaverCS6\configuration\shared\webassist\cssmenuwriter\shared.js(error 3)"" ..I received this m
I had this error when Dreamweaver first starts up. "The following Javascript error(s) occurred: Unable to open script file"C:\Programfiles(x86)\adobe\adobedreamweaverCS6\configuration\shared\webassist\cssmenuwriter\shared.js(error 3)"" ..I received this message three times when dreamweaver starts but with different webassist extensions. they are cssSculptor, google maps pro, cssmenu writer. So I removed these extensions from dreamweaver. Now I get the following message when dreamweaver starts. "Unable to fine file WA_Kuler.htm in the configuration/Floaters directory the floater will not be show. I get the same message three times but with different extension names. WA_Sitetools.htm and WA_sitetools_Progress.htm and the WA_Kuler.htm. I have already removed the cache file but still the same problem. How to we fix this?
for the floaters errors, reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
for the other error, what versions of the extensions are you installing?
