upload form email verification
Thread begun 1/21/2014 10:06 am by pat356751 | Last modified 1/21/2014 12:18 pm by Jason Byrnes | 3230 views | 7 replies |
pat356751
I'm trying to use Create Email Message to verify the upload was successful via email. Should the trigger be "Any Upload Successful" and the To field contain <?php echo $row_SecurityAssistusers['UserEmail']; ?> to send the user an email verification?
yes, to send the email if an an upload is successful, the trigger should be "Any Upload Successful".
as for the to address, using:
that would assume that there is a recordset named SecurityAssistusers that is properly configured to return the users email address.
pat356751
For some reason email verification isn't working. Can someone look at the attached file and see if there are any code errors that can cause this problem?
Thanks,
i dont see an obvious error. to help troubleshoot, add the following code to the success page:
<?php @session_start(); var_dump{$_SESSION); ?>
this will write the session contents to the success page, post this back
if you change the email trigger to any form post does it work?
pat356751
I get a blank success page with the added code.
sorry, typing to fast, the correct code is:
<?php @session_start(); var_dump($_SESSION); ?>
pat356751
It doesn't work with any form post. The success page posted:
array(25) { ["WAENCRYPTEDRETURNUSED"]=> bool(false) ["WAENCRYPTEDRETURNSUCCESS"]=> bool(false) ["Last_CAPTCHA"]=> int(1390333740) ["captcha_Security_Code"]=> string(5) "MAr6z" ["registration_upload"]=> string(0) "" ["waue_registration_1_Status"]=> string(7) "Success" ["waue_registration_1_Index"]=> int(1) ["waue_registration_1_From"]=> string(13) "tsec@mtsu.edu" ["waue_registration_1_To"]=> string(0) "" ["waue_registration_1_Subject"]=> string(21) "Registration Complete" ["waue_registration_1_Body"]=> string(6793) " --WAMULTIBREAKWA Content-Type: text/plain; charset="UTF-8" Content-Transfer-Encoding: 8bit Registration is complete tsec@mtsu.edu Form Submitted: 1-21-2014 | 1:50 PM CST Registration group Email: pat.govan@mtsu.edu Registration group Password: Asdfg13 Registration group Confirm: Asdfg13 Registration group First Name: pat Registration group Last Name: govan Registration group Address: 326 Registration group Address 2: adfgg Registration group City: mboro Registration group State: tn Registration group 10 Zip: 37130 Registration group 11 Country: United States Registration group 1 Phone: 123456789 Registration group 1 Fax: Hidden Field: Registration submit: Register Additional Notes: You can upload an update your files anytime at http://stem29.mtsu.edu/tsec/userupdate.php . --WAMULTIBREAKWA Content-Type: text/html; charset="UTF-8"
tsec@mtsu.edu
Hidden Field:
Additional Notes:
--WAMULTIBREAKWA-- " ["waue_registration_1_Header"]=> string(400) "MIME-Version: 1.0 Content-Type: multipart/alternative; charset="UTF-8"; boundary="WAMULTIBREAKWA" From: tsec@mtsu.edu Cc: tsec@mtsu.edu Bcc: pat.govan@mtsu.edu Reply-To: tsec@mtsu.edu Return-Path: tsec@mtsu.edu X-Sender: tsec@mtsu.edu X-Priority: 1 Date: Tue, 21 Jan 2014 13:50:19 -0600 (CST) Message-ID: <1699083281.635f249a254bf4e0d4665fc739c64913@mtsu.edu> Organization: tsec X-Mailer: php script " ["waue_registration_1_Log"]=> string(29) "Sending To: ... Success
" ["WAVT_registration_Errors"]=> string(0) "" ["SecurityAssist_UserID"]=> int(47) ["WAVT_userupdate_Errors"]=> string(0) "" ["userupdate_uploadfile"]=> string(57) "GEGardner Abstract STEM Ed Research Conference MTSU_3.doc" ["waue_userupdate_1_Status"]=> string(7) "Success" ["waue_userupdate_1_Index"]=> int(1) ["waue_userupdate_1_From"]=> string(20) "TSEC " ["waue_userupdate_1_To"]=> string(18) "pat.govan@mtsu.edu" ["waue_userupdate_1_Subject"]=> string(28) "Verification and upload Form" ["waue_userupdate_1_Body"]=> string(3792) " --WAMULTIBREAKWA Content-Type: text/plain Content-Transfer-Encoding: 8bit Received Upload File Form Submitted: 1-21-2014 | 2:18 PM CST User Update group UserEmail: pat.govan@mtsu.edu User Update group UserPassword: Asdfg13 User Update group Confirm: Asdfg13 UserUpdate submit: Upload Your file has been recieved. You can upload an update your files anytime at http://stem29.mtsu.edu/tsec/userupdate.php . Thanks. --WAMULTIBREAKWA Content-Type: text/html
Thanks.
--WAMULTIBREAKWA-- " ["waue_userupdate_1_Header"]=> string(356) "MIME-Version: 1.0 Content-Type: multipart/alternative; boundary="WAMULTIBREAKWA" From: TSEC Cc: tsec@mtsu.edu Bcc: pat.govan@mtsu.edu Reply-To: tsec@mtsu.edu Return-Path: tsec@mtsu.edu X-Sender: TSEC X-Priority: 1 Date: Tue, 21 Jan 2014 14:18:52 -0600 (CST) Message-ID: <683607874.635f249a254bf4e0d4665fc739c64913@mtsu.edu> " ["waue_userupdate_1_Log"]=> string(47) "Sending To: pat.govan@mtsu.edu... Success
Thank you for the update.
the status says it was passed to the SMTP server successfully:
in the email settings, what did you enter for the SMTP server?
Who is your host?
Depending on your host, you may need to set certain options in Universal Email.
Some hosts will work if you leave the SMTP Server setting on the Email Server Tab blank, others will require that you enter the SMTP server address.
Some will work using the standard Mail protocol, other will require that you use the Pear Mail for SMTP, some using Pear mail will require authentication.
Some hosts may require that the from address being used be a valid email address for your domain. Some may require that the option to include the from Email address be passed as an extra parameter.
To be successful with Universal Email, you will need to know the requirements of your host for sending an email using a PHP script.
Also, double check your Spam folder, it is possible that the email is being trapped as spam.
