Lost Dynamic MySQL Database Connection
Thread begun 1/21/2014 3:53 am by beawizz1437297 | Last modified 2/07/2014 6:52 am by Jason Byrnes | 5070 views | 9 replies |
beawizz1437297
Been having a few problems lately just installed ecart6 and for some reason my Dynamic MySQL Database Connection selection has gone? Ive tried several times reinstalling and nothing still very confusing has this feature been removed?
I have also attached screen pics of the extentions installed with the Datebridge install
Sorry about that, This is a bug with the new builds that will addressed as soon as possible.
We'll probably do a hot fix to the installer that you can uninstall the current version and reinstall it to have the fix applied, I will let you know when it is available.
There was an update to eCart 6.0.2 and Data Bridge 1.1.7 released last night that should correct the problem of not having the Dynamic Connection access point.
uninstall the previous version from the extensions manager, then download and install the new ones.
beawizz1437297
Hi Jason
Thank you for your info. However I have done the removal and update but still no joy yet the dynamic connection access is still not there? I have also reset my workspace and deleted the WinFileCache.dat file but nothing has changed with my program menu.
hmm, I thought this error was fixed in the last update, but it looks like not, I have logged this in our system to have it corrected for the next update that should be available tomorrow. I'll update this thread when it becomes available.
beawizz1437297
Hi Jason,
Just wondering if you have any fix soon for the error problem with not having a Dynamic MySQL Database Connection in the program, I know I can use the standard connection that comes with dreamweaver but I would like the have the added Dynamic MySQL Database Connection from the suite. if possible. thanks
We will have an update to Data Bridge released hopefully tomorrow to correct the problem. i will update this thread when it is available.
eCart 6.0.3 and Data Bridge 1.1.8 have been released to correct this problem.
uninstall the previous versions from the extension manager before installing the newer ones.
beawizz1437297
Wonderful, uninstalled then downloaded updates, worked great thank you I have my menu back, awesome job thanks again
you're welcome.
