Insert Checkout Form and Empty Values
Thread begun 1/21/2014 12:56 am by Me | Last modified 1/31/2014 6:31 pm by Jason Byrnes | 4039 views | 6 replies |
Me
Hi
Just updated to eCart 6.0. See the attached image, you'll not there are two Insert Checkout Form Links in the toolbar. I'm guessing this is an error, if not please can it be explained why there are two that appear to do the same thing.
On the same subject, when using Insert Checkout Form > Choose PayPal Standard, quite simply there are are no variables placed in the hidden fields so that when it goes to PayPal, the message on the PayPal pages says something like Shopping Cart Empty. I guess this is because the fields contain no 'real' variables? ON previous versions, upon doing the same, the Checkout Form would contain the required fields and within them wold be the variables assigned that would then be posted to PayPal.
Please advise.
The second one is a bug that i have logged in our system. It should be corrected in the next update.
in the insert checkout form behavior, after you select a remote checkout form for paypal standard, click the pencil icon to edit the form and set the element bindings
Me
I think perhaps my query has been misunderstood. The values I am referring to in the checkout are the actual values (of the shopping cart order) that are not being password to PayPal. In previous versions 5 etc -, when the checkout form was added to the page, the order value etc, would already be stored in the post variables. However, now they are empty.
Here is the form that is added to the page...note that the cart values (amount / qty / name etc) are empty and would nnormally look something like
item_name_<?php echo $ShoppingCart_Index+1; ?>
<form name="checkout_PP_LI_Hid" action="https://www.PayPal.com/cgi-bin/webscr" method="post">
<div class="eC_PurchaserInfoWrapper">
<div class="eC_CheckoutFormBody"></div>
</div>
<table class="eC_ButtonWrapper" border="0" cellpadding="0" cellspacing="0">
<tr>
<td><input type="hidden" name="business" id="business" value="test@here.com" />
<input type="hidden" name="amount_" />
<input type="hidden" name="item_name_" />
<input type="hidden" name="item_number_" />
<input type="hidden" name="quantity_" />
<input type="hidden" name="on0_" value="" />
<input type="hidden" name="os0_" value="" />
<input type="hidden" name="on1_" value="" />
<input type="hidden" name="os1_" value="" />
<input type="hidden" name="handling_cart" id="handling_cart" value="" />
<input type="hidden" name="tax_cart" id="tax_cart" value="" />
<input type="hidden" name="no_note" id="no_note" value="0" />
<input type="hidden" name="no_shipping" id="no_shipping" value="0" />
<input type="hidden" name="cancel_return" id="cancel_return" value="" />
<input type="hidden" name="return" id="return" value="" />
<input type="hidden" name="cmd" id="cmd" value="_cart" />
<input type="hidden" name="upload" id="upload" value="1" />
<input type="hidden" name="currency_code" id="currency_code" value="GBP" />
<input type="hidden" name="address_override" id="address_override" value="0" />
<input type="hidden" name="first_name" id="first_name" value="" />
<input type="hidden" name="last_name" id="last_name" value="" />
<input type="hidden" name="address1" id="address1" value="" />
<input type="hidden" name="address2" id="address2" value="" />
<input type="hidden" name="city" id="city" value="" />
<input type="hidden" name="state" id="state" value="" />
<input type="hidden" name="zip" id="zip" value="" />
<input type="hidden" name="country" id="country" value="" />
<input type="hidden" name="bn" id="bn" value="WebAssist.eCartPHP.Pro" />
<input type="image" name="Checkout" id="Checkout" value="Checkout" alt="Checkout" src="WA_eCart/Images/Pacifica/Btn3_EN_checkout.gif" class="eC_ImageButton" /></td>
</tr>
</table>
</form>
Ok i see, I have a logged a bug for that issue as well, it should be fixed in the next update to be released hopefully tomorrow. I will update this thread when it becomes available.
Me
OK...I have downloaded today, 6.0.2 and see the problem still exists. I will for now revert to 5.
An update should be available in the next day or 2, i will let you know when it becomes available.
eCart 6.0.3 has been released to correct this problem.
uninstall the previous version from the extension manager before installing the newer ones.
