Jquery Validation
Thread begun 1/20/2014 10:21 am by Php | Last modified 1/21/2014 2:29 pm by Jason Byrnes | 3331 views | 21 replies |
Php
Jquery Validation
I have created my own form on dreamweaver and have used the jquery validation which does work and does not allow the form to be processed without the fields to be filled in. However the jquery validation does not check the field to see whether it contains the same letters as the capatcha. How can I solve this.
captcha validation is done using server side validation.
see the form toolkit getting started guide:
http://www.webassist.com/tutorials/Getting-Started-with-Form-Toolkit
Php
ok i get pass server validation part but when i get to validation show if it says apply to capatcha in the code but when i do the who things dissappears?
why is that happening?
I dont follow, p,ease provide more details.
Php
when i follow this tutorial http://www.webassist.com/tutorials/Getting-Started-with-Form-Toolkit i get passed the server validation then when it inserts the validation if show behaivour in my code then the capatcha disappears from my form?
it sounds like you are adding the show if around the captcha image rather than creating the error message and adding the show if around the error message.
add the error test to the page, select it, then add the show if around the error test.
Php
ok i got you now the capatcha is not server validating? im following the exact steps?
no, you shoul validate captcha using server validation.
the validation show if behavior is used to show an error when validation fails.
so add the error to the page, select it, then add the validation show if behavior and set the trigger to show the error if captcha validation fails.
Php
[QUOTE=165841;Jason Byrnes]no, you shoul validate captcha using server validation.
so add the error to the page, select it, then add the validation show if behavior and set the trigger to show the error if captcha validation fails.[/QUOTE
Hi I followed the whole tutorials numerous times but its not validating I want this simply to work? It's my first time using your extensions and this is not working can help to trouble shoot this? I'm using xamp for testing ?
send a copy of the page please, and a more detailed explanation of how it is "not working"
what _does_ it do versus what you expect it to do.
