Data Assist isn't linking required files correctly
Thread begun 1/19/2014 7:08 am by Daryl | Last modified 1/29/2014 9:47 am by Jason Byrnes | 2567 views | 5 replies |
DarylBeta Tester
Jquery is being linked as;
<script src="//ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
<script src="//ajax.googleapis.com/ajax/libs/jqueryui/1/jquery-ui.min.js"></script>
Should it not be;
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
<script src="http://ajax.googleapis.com/ajax/libs/jqueryui/1/jquery-ui.min.js"></script>
The Tooltips are being linked as;
<link rel="stylesheet" href="webassist/jq_validation/Bloom.css">
But should be
<link rel="stylesheet" href="../../webassist/jq_validation/Bloom.css">
The validation script was linked as;
<script src="webassist/jq_validation/jquery.h5validate.js"></script>
But Should be;
<script src="../../webassist/jq_validation/jquery.h5validate.js"></script>
for the google path, that is fine. The http: is implied when using a double slash.
for the other paths, this seams to be bug for pages that are in a subdirectory, I have logged the bug to have it corrected in the next update.
DarylBeta Tester
Hi Jason
When will the next update be please?
I am using Data Assist 1.1.7
that should be fixed in 1.1.7, the paths in your screen shot look correct, no?
DarylBeta Tester
both of the ajax links are missing the http:
and the other links were missing the ../../ that they should have had
the ajax link does not need the http. it is implied when double slash is used.
I am not able to reproduce the paths for the others, perhaps try deleting the cache file from the configuration folder or renaming the configuration to start a clean install.
