Form won't submit
Thread begun 1/17/2014 5:57 am by Daryl | Last modified 1/20/2014 8:17 am by Jason Byrnes | 4723 views | 14 replies |
DarylBeta Tester
Form won't submit
Since upgrading to the latest versions Ive had quite a few problems....
Framework Builder Theme is causing errors, just figured out that I now have to style my Data Assist Pages by opening up Form Builder after the forms have been created and now have forms that won't submit.
I have a fairly simple form with text fields, text area fields, and checkboxes and file upload field, but when I submit the form I get redirected back to my form, no data is submitted and no error message is shown and no data is in the form that I am directed too so I have to retype it all each time.
There is no form validation required fields so thats not stopping it.....
Page posted below in a zip file and addition links etc also.
the trigger for the insert record behaicvor was set to use a button named Insert, but the insert button on the page was named Default_submit
i changed the trigger to use the button that exists.
DarylBeta Tester
Thanks Jason
The form was created by DataAssist and hadn't been amended....
I have not been able to reproduce this problem, but will keep my eye out.
DarylBeta Tester
Hi Jason, I have no idea whats going on but I'm still having loads of problems!
I created an insert form using data assist and put in a folder called plugins
I created a page from a theme and then inserted the plugin using framework builder.
Now the form formatting has been lost and I'm now getting 4 errors on the page...
Are these bugs, am I all of a sudden doing something wrong or is there a new way to achieve these things as its always worked in the past...
DarylBeta Tester
Please see below
I see the formatting on the page and don't see the errors?
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
DarylBeta Tester
Username in the Private area
daryl, I found the problem
in your template, yu have 2 editable regions in the head section named head
Since they share the same name, the theme is only recognizing the first one.
on the add prctitioner page, change the following code:
<!-- InstanceBeginEditable name="Head" --><!-- InstanceEndEditable -->
<!-- InstanceBeginEditable name="head" -->
<?php echo((isset($WA_practitioners_insert_1389970598536))?$WA_practitioners_insert_1389970598536->Head:"") ?>
so that the Plugin head section is in the first head editable region:
<!-- InstanceBeginEditable name="Head" --><?php echo((isset($WA_practitioners_insert_1389970598536))?$WA_practitioners_insert_1389970598536->Head:"") ?><!-- InstanceEndEditable -->
since it is in the second one, it is being ignored when the theme is applied.
avoid using the same name when creating editable regions.
