CS6\Configuration\Shared\WebAssist\Library\WA_UI.js (error 3)
Thread begun 1/16/2014 3:05 pm by bob.lee357763 | Last modified 4/11/2014 12:04 pm by Jason Byrnes | 2970 views | 4 replies |
bob.lee357763
Following update of extensions have been receiving this error
CS6\Configuration\Shared\WebAssist\Library\WA_UI.js (error 3).
Please advise fix
we found a problem with the WA installer, will are comping new builds to address the problem as I type this and they should be available latter today. I will let you know when that happens.
New Dot releases have been uploaded to the download section for:
eCart 6.0.1
Design Extender 1.1.7
Data Bridge 1.1.6
Free Tools 1.0.8
these versions should correct the problems you are having.
uninstall the previous versions from the extension manager, then install the new ones
bblue
same issue - DW CC
I am having same issue with all updates installed today- april 11.
Data bridge
design extender
eCart 5
free tools.
will reinstall updates (cant uninstall previous versions first because the updates being installed is what prompted the error - a paradox :) ) and hopefully won't lose my custom presets. I will reply if it works to help anyone else .
with eCart 5, you should install it first, then start and close dreamweaver, then install the other extensions.
When installing a new version of an extensions, you must uninstall the previous version first even if you are installing the same version.
For Example, if you have Data Bridge 1.1.9 installed in the extension manager, and you wish to install it again, you must first uninstall it.
if you have custom presets you wish to save, use the preset manager to export them then import them after installing again.
