Upgrade 5 to 6 problems
Thread begun 1/16/2014 10:56 am by neo314 | Last modified 1/16/2014 5:30 pm by Jason Byrnes | 1382 views | 3 replies |
neo314
Historically, it has always been necessary to remove the previous WA extension to install the new one. I am attempting to remove eCart 5.07 from DW CS6 and the removal process appears to almost complete and then crash the extension manager.
What is the fix for this problem. This is the third time I have encountered this kind of problem removing WA extensions (the other 2 were with Free Tools). It is very frustrating.
follow step 12 of the adobe troubleshooting guide to rename the configuration folder:
http://helpx.adobe.com/dreamweaver/kb/troubleshoot-javascript-errors-dreamweaver-cs4.html#main_user_config
with eCart 6, and the new versions of Data Bridge, free Tools, and Design extender, we are implementing a new install scheme that should prevent these issues in the future.
neo314
Hi Jason,
Thanks for the reply. I know you can't do anything about it, but I have to say that it always pisses me off to be told to rename the configuration directory. That really says, we broke your DW. I have a lot of other extensions besides WA installed. It is a major hassle that never seems to be recognized by the vendor.
If it helps, I found that if I disable all of my WA extensions (eCart last), I could remove eCart 5.07 without crashing the extension manager.
like i said in my original reply with eCart 6, and the new versions of Data Bridge, free Tools, and Design extender, we are implementing a new install scheme. This new install scheme makes minimal use of the extension manager and should prevent issues with the extension manger in the future.
Glad to hear you found another work around.
