Two other errors when applying dataassist wizard
Thread begun 1/16/2014 10:32 am by Miguel | Last modified 1/20/2014 12:06 pm by Miguel | 4542 views | 8 replies |
Miguel
After the fresh installation i can not run successfully the data assist wizard it throws randomly these 2 errors when it reaches to build the update page and stops there, not generating the rest of the pages like detail and results, i know there will be an update but wanted to report this in case to see if it makes it for today's corrections, right now with this error it makes the tool unusable.
i think this is related to the other problem you posted and should be fixed by the updates we will be releasing later today. I will let you know when they are available.
Miguel
Here is another error after the upgrade this displayed randomly when i click on the code view part, now i dont even have something with paypal on the hole site
That error sounds like a problem with the free Tools installation.
uninstall Free tools from the extension manager, then open DW to launch the free Tools uninstall script.
once it is uninstalled, you can try reinstalling from the latest version available in the download center.
Miguel
Hello jason after unistalling free tool it works without giving that error but if i install it back it brings it out, also any words on the problem with dataassist i can not create yet any pages with update features
We updated the WA installer for Data Bridge to correct this.
Uninstall Data Bridge in the extension manager, then Re install it, the WA Installer will run when you start up dreamweaver and open a php page, the updated installer files should correct this issue.
Miguel
i do have the latest release from Released: January 16, 2014 the problem persisted did not fix the problem preventing when using the wizard with dataasist:
Data Bridge
Current version: 1.1.6
Design Extender
Current version: 1.1.7
Free Tools
Current version: 1.0.8
ecart
Current version: 6.0.1
This error is addressed in the following post:
http://www.webassist.com/forums/post/165610/
Also here
http://www.webassist.com/forums/posts.php?id=33287
We updated the installer files to add a hot fix.
you need to uninstall the extensions from the extension manager, then reinstall them.
you will still use the same MXP file, but when it downloads the installer files from our site, it will include the update.
uninstall Data Bridge and free tools from the extension manger, then reinstall them to launch the WA installer and install the updated files
Miguel
Ok just did a clean upgrade i deleted all from the extension manager, cleared cache, downloaded the extensions, and installed them again.
The data assist wizard still stops when making the update page see screenshot with the error it throws, also when i go in to the css menu writer i get another error see also the private screenshot.
The most important problem is still there and i can not create pages using the dataasist wizard with that error since it stops the process at that point.
