Redirect to different pages
Thread begun 1/16/2014 9:17 am by Daryl | Last modified 1/16/2014 12:32 pm by Jason Byrnes | 2409 views | 5 replies |
DarylBeta Tester
in 2010 I asked this same question, but was wondering if there was a better way to handle this now....?
the thread is here - http://www.webassist.com/forums/posts.php?id=9698
I have a form with a single select list, the values are blank, 1, 2 and 3.
When I submit the form I would like to be redirected to a different page depending on my selection.
1 would take me to page a, 2 would take me to page b and 3 would take me to page c
i would use a switch case statement:
if(isset($_POST['select'])) {
switch($_POST['select']) {
case "1":
$redirPage = "page1.php";
break;
case "2":
$redirPage = "page2.php";
break;
case "3":
$redirPage = "page3.php";
break;
default:
$redirPage = "default.php";
break;
header("Location: ".$redirPage);
this example assumes the name of the select is select, adjust accordingly.
DarylBeta Tester
That looks a lot neater!
Where would I put this code and what would I do with the $WA_redirectURL = code?
the code would go where you want the redirect to happen, so after any other code that processes the form.
this code would replace the $WA_redirectURL code, since it already has the header function in it.
DarylBeta Tester
Thank you Jason - Your a star as always!!
you're welcome.
