Changing field size after using Data Assist wizard
Thread began 1/16/2014 8:19 am by sandy170299 | Last modified 1/16/2014 2:03 pm by Jason Byrnes | 626 views | 3 replies |
sandy170299
<input id="address" name="address" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("attendeesupdate","address"):"".$row_WADAattendees["address"]."")); ?>" class="formTextfield_Large" tabindex="5" />
How do I change this to an Extra Large field? I can't remember if it's X-Large, or X_Large, or something else, becasue it doesn't seem to make a difference. Thanks!
what form design did you use?
it should be formTextfield_XLarge selector.
did you set any of the elements to use the x-large setting?
if no elements use the x-large setting, it may not add the selector to the css when it is generated since it is not needed.
sandy170299
No. There were no other elements assigned XLarge. Which stylesheet controls this? I wasn't able to find it. Thanks!
in your pages there will be a style sheet reference for the form design you used.
if no elements where assigned the X large attribute, it would not have been added to the style sheet when the pages whertre generated.
