Install of 115 data bridge upate now produces error on launch
Thread begun 1/16/2014 7:44 am by operations439446 | Last modified 1/24/2014 10:00 am by Jason Byrnes | 5605 views | 9 replies |
operations439446
After installing (via automatic install) Data Bridge 115 I get the following on launch of DW CS4:
The following JavaScript error(s) occurred:
Unable to open script file "C:\Program Files (x86)\Adobe\Adobe Dreamweaver
CS4\Configuration
WA_Configuration.js" (error3).
I have already reset my workspace and deleted the dat files.
This is on win7 i7processor 8 gigs ram all updates are up to date.
Bob
we found a problem with the WA installer running on Mac OS and DW C4, will are comping new builds to address the problem as I type this and they should be available latter today. I will let you know when that happens.
New Dot releases have been uploaded to the download section for:
Data Bridge 1.1.6
these versions should correct the problems you are having.
uninstall the previous versions from the extension manager, then install the new ones
operations439446
Hi Jason,
Uninstalled 115. Installed 116. No cigar here is the message I now get on launch:
Unabvle to open script file "C:\PRogram Files (x86\Adobe\Adobe DreamweaverCS$\Configuration\WA_Configuration.js" (error3).
Thoughts?
open a PHP page, this should start the WA Installer to finish installing the extension.
once the install is finished, restart DW.
operations439446
Launched DW, completed install and closed DW.
Launch again and I get the same error: Unable to open script file "C:\Program Files (x86)\Adobe\Adobe Dreamweaver
CS4\Configuration WA_Configuration.js" (error3).
Thinking it's an old file somewhere I move forward anyway. I open a php page and try to create a form. On first click anywhere on the dia box it spins out for a while and produces an error:
Corrupt JPEG data: 106 extaneous bytes before marker 0xd9
Have to close DW. FTI I am on a 64bit system.
I like the new 3 tab interface but can't get it to work yet. Grrrrrrr.
try recreating the users configuration folder as outlined in step 12 of the Dreamweaver troubleshooting guide:
http://helpx.adobe.com/dreamweaver/kb/troubleshoot-javascript-errors-dreamweaver-cs4.html#main_user_config
then reinstalling.
operations439446
Rebuilding per section 12 as you pointed out fixed things.
As always, thanks again,
Bob
glad to hear it is working.
operations439446
Jason, as above same thing except I click OK to the last error message and everything seems to be working including the preview window. I am going to make a form and see if it works. Might be OK even with the warnings? Strange stuff.,
