Installing eCart 6 on Dreamweaver CC with eCart 5 installed
Thread begun 1/16/2014 12:40 am by Ian Sheldon | Last modified 1/16/2014 8:30 am by Jason Byrnes | 1345 views | 1 replies |
Ian Sheldon
Hi
This morning I purchased and installed eCart 6.
I use Dreamweaver CC (on Mac) and went to uninstall eCart 5 only to find that I couldn't due to it not showing up in the Extension Manager.
I went ahead and installed eCart6 anyway, only to find that on opening Dreamweaver, (I downloaded the eCart 6 files and rebooted) that the interface was still for eCart 5.
I then decided to uninstall eCart 6 using Extension manager and went back into Dreamweaver to see if it had removed all the menu and server behaviour entries. It had. I also was greeted with a hole host of JS errors (too many to make a note of, probably 50 or so).
I then closed DW and cleared the .dat cache file etc, and reinstalled eCart and so far it seems to be working.
I just wanted to let people know, that the installation process doesn't seem to take into account removing eCart 5 for those that can't see it in the Extension Manager. Is it possible to create an uninstall tool for eCart 5 for CC users?
Cheers
Ian
The only way to uninstall eCart 5 from DW CC would be to rename the configuration folder, then re install the extensions . see step 12 of the adobe troubleshooting guide:
http://helpx.adobe.com/dreamweaver/kb/troubleshoot-javascript-errors-dreamweaver-cs4.html#main_user_config
