debugging ‘hidden’ table rows in IE 11
Thread begun 1/15/2014 11:34 am by CraigR | Last modified 1/16/2014 1:45 pm by Jason Byrnes | 4070 views | 3 replies |
CraigRBeta Tester
I have a search form on a 2 year old site which is misbehaving in IE 11.
A customer has commented that the search results are not visible, (even though rows are returned).
There is no issue in Chrome or FF
When I try to debug, I see the row data is present in the debug window, (but not the dom explorer as far as I can see)
Grateful if someone can help me debug this,
http://www.centuryspring.com/Store/search_compression.php
Try setting the material to music wire, closed ends and there should be 2 rows returned.
something in the jquery.tablesorter.pager.js script is not compatible with IE 11. if i remove this line:
<script type="text/javascript" src="../js/jquery.tablesorter.pager.js"></script>
the table shows.
CraigRBeta Tester
Thanks Jason, that really helped
I found an updated plugin which resolves the issue.
you're welcome.
