Data Bridge 1.1.5 - Delete Record does not work anymore
Thread begun 1/15/2014 10:49 am by Willi Schneider | Last modified 1/16/2014 10:44 am by Jason Byrnes | 4541 views | 17 replies |
Willi Schneider
Hi WA-team
I've just installed the new version 1.1.5 and ran into a big problem:
Delete Record does not work anymore.
To reproduce:
Run "DataBase" ->> "DataAssist Pages"
No matter if I chose a DataBridge Preset or start from blank
System Info:
Win 7 PRO
DW CS6 12.0 Build 5861
Installed WA-Extensions:
FreeTools 1.0.7
DataBridge 1.1.5
DesignExtender 1.1.6
eCart 5.0.7
Cleared DWCache file, reset workspace
Thanks for reporting this issue, I will log a bug for the problem
in the webassist/progress_bar/jquery-blockui-formprocessing.js file change:
if ($('#'+formId).h5Validate) {
if ($ && $('#'+formId).h5Validate) {
Willi Schneider
Hallo Jason
Thanks alot, that did it!
Please allow one additional question: Since the new versions come with the new WA installer, does that mean, that such a bug fix would only require to run the installer and just download that corrected jquery-blockui-formprocessing.js file?
No, we would release an updated build, you would uninstall the extension from the extension manager and install the new build, the new build will run the installer again to install the new files.
Willi Schneider
Hi Jason
o.k. Thanks for the info.
Willi Schneider
Hi Jason
The error has gone on the results page, however on the details page, deleting still does not work, and I get the following errors:
Warning: mysql_select_db() expects parameter 2 to be resource, null given in D:\xampp\htdocs\websites\demmelsixtus-ag\admin\db_ss_2\startseite_detail.php on line 20
Warning: mysql_query() expects parameter 2 to be resource, null given in D:\xampp\htdocs\websites\demmelsixtus-ag\admin\db_ss_2\startseite_detail.php on line 24
Willi Schneider
see PM
see PM
Willi Schneider
See PM
