Changing Field Order in Security Pages Wizard
Thread begun 1/13/2014 10:10 am by Mike Perry | Last modified 1/13/2014 11:33 am by Jason Byrnes | 3883 views | 7 replies |
Mike Perry
Can I change the field order in the Create Pages Wizard?
Building the double opt-in registration from the WA tutorial. I'm using a pre-configured database for the Users table. There are fields in the table that are not included in the "stock" Users form. I can add the fields to the registration and update pages with Manage Pages, but I cannot alter the order in the generated form.
Since the form structure and other attributes are not saved, there is no easy way to change.
Also -- is there a way to create non-dynamic menu fields and include the options? Adding after the fact seems to mess up the Spry validations. . .
In the security assist wizard, go to the manage pages tab, select the registration page and click the edit button.
While editing the registration page, you can move the columns to the desired location.
you cannot add static contents to list elements in the wizard, you need to add those after the page is created.
In design view, selct the list, in the property inspector, click the List Values button to add values.
Mike Perry
I've tried in the Edit Page to move the column names by clicking the arrow buttons on the top right. A couple of fields will move up and down (password,First/Last Name, Address). After that none will move. . .
I'm not able to reproduce.
try Disabling the preview. Go to WebAssist -> Preferences in the preview section, select the disable option.
also, and Delete the Dreamweaver Cache file from the users configuration folder:
and reboot.
Mike Perry
That did it. . .
Preview causes some problems, doesn't it??
it can, we will be updating the preview engine to offer some other choices that will hopefully correct the issues.
Mike Perry
Thanks Jason.
ECart 6 soon???
This week we hope.
