Create dynamic folder from recordset value
Thread begun 1/13/2014 1:15 am by FrankJay | Last modified 1/13/2014 1:23 pm by Jason Byrnes | 3249 views | 7 replies |
FrankJay
I have searched and read related posts and do not find exact solutions.
I have created the admin pages for photo Administration. The insert page has a dynamic drop-down menu to select an issue. Based on the selected issue, the next dynamic drop-down menu will only display the articles related to the issue. This is working perfectly.
The image "Upload Folder" contains static folders and a dynamic value from the issue recordset:
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../img/archives/articles/".$row_WADAMenuri_arcPhotoIssueID['IssueNumber'] ."",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "2",
'ResizeWidth' => "220",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
When I insert the first photograph, a dynamic folder is created successfully. However, when I insert more photographs for different issues, the photographs are all added to the original dynamic created folder. No new dynamic folders based on the issue is created.
Kindly assist.
How/where would I get/retrieve the dynamic-created-folder above to display thumb for the results page?
eg.
<img src="../img/archives/articles/list/(dynamic-created-folder)<?php echo $row_WADAri_PhotosArchive['ri_arcPhotoLandscapeFile']; ?>" alt="alt">
Thanks in advance for the assistance.
In the upload behavior, don't use the Recordsdet for the folder name, use the Issue number select list.
the select list will contain the selected value when the page is posted. The recordset will always ever return the first record.
FrankJay
Not sure
Thank you for your reply.
Not sure how to implement your instruction.
"In the upload behavior, don't use the Recordsdet for the folder name, use the Issue number select list."
Please elaborate on "use the issue number selected list." How would I do this when selecting the upload behaviour? Would I do this in the file manipulation: upload wizard?
Should I click on the dynamic icon next to the upload folder field?
Apologies for my ignorance
in the upload file server behavor, click the lightning bolt icon next to Uplaod folder.
from the dynamic bindings expand the form collection and select the issue number select list
FrankJay
Now working
I have successfully implemented your instructions and tested. Dynamic folder now creating.
Now that that's under the belt, I remain with one question.
How would I be able to include to the image path, the dynamically created photo folder image to be displayed on the results page?
First time working with dynamically created image folders.
Please advise.
make sure the recordset includes the ri_PhotosArchive.ri_arcPhotoIssueID column, and use the biding for that column for the dynamic folder.
FrankJay
Working as well
Thanks Jason,
Everything working perfectly.
Appreciate your assistance and instructions.
you're welcome.
