Is there any documentation available for eCart 4.5.2?
Thread begun 1/11/2014 1:27 pm by veramilo | Last modified 1/14/2014 5:46 am by Jason Byrnes | 1790 views | 3 replies |
veramilo
When I first purchased eCart a few years ago, it was version 4 and I wasn't able to implement it so I set it aside until I had more time. Last November, I updated it to 4.5.2 and downloaded all the supporting files and documentation I could find. I finally have a free stretch of time now, but when I opened the GSG pdf, I found it's for version 5, and none of the help menus built into the app work (Flash errors, even when I instruct Flash to trust the location). Now I'm also concerned that ALL the support files I downloaded are for 5. I haven't been able to verify any of this from the file names.
I cannot justify the cost of repurchasing without first having some success with the version I already bought so I'm hoping I can get the 4.5 documentation.
There is not documentation available that is specific to V4 at this time, but the concepts in the V5 documentation are still the same.
The process of creating a store using eCart from v4 to v5 is not changed:
1) Create the product catalog
2) Create the eCart object
3) add the Add to cart buttons to your product pages.
4) Create a page to display the cart contents using the Cart Display manager
5) Create the checkout pages using the Checkout wizard.
the main differences between V4 and V5 will be in the way the interfaces look an some of the options. the core concepts are still the same.
the support files you downloaded should still work also.
If there is a particular step you are unsure of, ask here.
anonymous
Thank you so much!
Would you have any idea why the "Help" button that appears on the various setting panels generates a Flash error in my browser?
whats the error?
I cant troubleshoot an error without knowing what it says.
