How do I import Data Assist design presets from DW CS5.5 to CS 6?
Thread begun 1/10/2014 8:39 am by sandy170299 | Last modified 1/17/2020 12:05 pm by Ray Borduin | 3035 views | 7 replies |
sandy170299
I just installed DW CS6 and I am missing my DA design presets, which were created in CS 5.5. How do I locate them and copy them to the new installation?
Also, to add to the problem, data assist keeps crashing in DW CS 6. I just get a "not responding" message and it hangs until DW just closes down. Is there a patch or something I can do to get it to work?
Thank you.
in DW CS 5, go to WebAssist -> Preset manager.
use the reset manager to export your presets.
then use the preset manager in DW CS6 to import them.
for the crash, try disabling the preview.
g to WebAssist -> Preferences in the Preview section, select the option to disable it.
the previews will still be available by clicking the preview place holder to open the preview in a browser.
sandy170299
Thank you. I installed windows updates this morning and had to uninstall data bridge and then reinstall it in order to keep it from crashing in Dreamweaver.
PatriceWebAssist
What location would older presets live? In configuration files? I am trying to find presets done several renamed config files ago.
The presets for DataAssist should be located in your user's configuration folder for Dreamweaver under:
Configuration/Shared/WebAssist/DataAssist/XML
PatriceWebAssist
Thank you!
To clarify, looking for the presets that I save per each client, per db table, ie, ClientName_testimonials... these are saved presets
I think those are in the Schema directory, so:
Configuration/Shared/WebAssist/DataAssist/XML/Schema
PatriceWebAssist
That's it! Thanks so much!
